February 24, 2020, 01:29:28 AM
24990 Posts in 2103 Topics by 1121 Members
Latest Member: AndrewCewly
The VIPER Garage  |  Generation-specific Viper Forums  |  RT/10 & GTS Viper Discussions  |  2001 GTS Door Window not attached
Author Topic: 2001 GTS Door Window not attached  (Read 1082 times)
DarcShadow
Fort Worth Motorcycle Riders
« on: April 05, 2018, 10:47:10 AM »
My passenger side door window on my 2001 GTS won't go up. I took the door panel apart and discovered that the window is not attached to the part that goes up and down. I have no idea what the part would be called or how it's intended to connect to the window.
Does anyone have an exploded view parts drawing that would show the part I need and possibly how it's connected to the window?
I refuse to tip toe through life only to arrive safely at death.
« Reply #1 on: July 21, 2018, 03:54:18 PM »
Yes, the pin is attached to a bracket glued to the window glass.  The winder motor and track has a moving plastic bracket that the cables move up and down.  Mine has popped out in me a few times already.  The plastic fixture can be replaced although I'm not so sure of the window bracket.
There is a fancy 'C' clip that slides into the white plastic carrier that is part of the middle window track.  It hold the "stud" from the window to the carrier.  You can easily unbolt the 3 motor bolts and the two track bolts and pull it out of the door to look at it.  Don't forget to disconnect the electrical connector.
Bad motors is a bit of a problem I was told, but I haven't seen that. just the one window popping out of the carrier/shuttle on my 98 Hennessey.
RomeoFus
« Reply #2 on: January 08, 2020, 05:41:18 AM »
How do you replace the plastic fixture? You just glue it back up?
« Reply #3 on: February 07, 2020, 11:12:46 PM »
No the plastic just slides on and the C clip holds it in place I think
« Reply #4 on: February 07, 2020, 11:13:34 PM »
I've seen them for sale on Ebay
