February 18, 2019, 05:51:24 AM
24625 Posts in 1938 Topics by 845 Members
Latest Member: Brandon.Rued
The VIPER Garage  |  Generation-specific Viper Forums  |  RT/10 & GTS Viper Discussions  |  code p1195 and p1196
Author Topic: code p1195 and p1196  (Read 1415 times)
britt
« on: September 02, 2015, 08:31:01 AM »
my 1998 gts at 27000 miles started showing these two codes together, i swapped in 2 new o2 sensors upstream and have same issue, any thoughts and why would both trip together ? :idk:
« Reply #1 on: September 02, 2015, 05:00:46 PM »
Stock?
Possible causes
- Faulty Heated Oxygen Sensor Bank 2 Sensor 1
- Very lean air fuel ratio (Intake Leak)
- Very rich air fuel ratio (Injector leak or bad mass air flow sensor)
I would change fuel filters.  Our 'modern' Oxygenated fuel (Gov requires 10% ethanol or comparble additive) has caused my fuel pump pre-filter to plug us with black stuff.  Guessing float plastic inside tank.
« Reply #2 on: September 02, 2015, 07:03:26 PM »
First thing I'd do is put die electric grease in the computer terminals.
Unplug harness.  Dab the pin with the grease and reinstall the 3 harness plugs.
britt
« Reply #3 on: September 03, 2015, 11:40:23 AM »
here i go jtin grease in hand :2thumbsup:
« Reply #4 on: September 10, 2015, 09:47:30 AM »
Any luck ?
britt
« Reply #5 on: September 22, 2015, 03:27:22 PM »
turns out fuel pump was putting out 7lbs pressure, replacing it now
britt
« Reply #6 on: September 23, 2015, 03:17:27 PM »
and where the hell do i get a fuel pump relay for my car!
« Reply #7 on: September 25, 2015, 01:55:53 PM »
The relay in the fusebox?  Check the How To section under part number thread.  Pretty sure I posted the common relay part number available at all auto stores
