June 18, 2019, 09:52:11 PM
The VIPER Garage  |  Generation-specific Viper Forums  |  RT/10 & GTS Viper Discussions  |  Pulled the clutch and found this...
Author Topic: Pulled the clutch and found this...  (Read 1005 times)
Ratical2
« on: August 27, 2016, 10:48:30 PM »
My throwout bearing failed, so I pulled the transmission to replace it along with the slave cylinder. I was surprised that it failed so quickly. It was replaced 35K miles ago.  I also removed the clutch from the flywheel to replace to pilot bearing and found what appeared to be a thick layer of powered rust.  Is this normal???
« Reply #1 on: August 30, 2016, 01:52:40 PM »
Steel flywheel?  I'd say Yes, that's normal.  The clutch creates heat cycles which  probably caused that rust.
Here's my stock Luk clutch which has about 62,000mi on it when I removed it from my Roe car.  Same rust dust around the center.
* Stock clutcch from my Sapphire GT (1) (570x380).jpg (196.05 kB, 570x380 - viewed 205 times.)
